usually a brake problem(front lockup) is caused by something at the other end of the car( rear brakes inadequate) from design issues or adjustments.
Bleed the brakes, check pressure at all calipers,you should be able to get over 1000psi---
I'll bet your rear brakes aren't working properly
Jerry
