Old 09-23-2007, 10:00 AM
CSCHWER CSCHWER is offline
Cobra Make, Engine: SPF 2682, Roush 427
I'm trying a 60 inch NAPA # 615-1644 speedo cable right now. It is wound opposite the first one I tried. I'll run it for a while and see. It will probably be OK with the new grease in the cable. I'll try a couple hours of 70 MPH driving and see what happens. Right now the speedo needle is about as steady as the tach. This cable I'm running now seems to fit better. ie the length of the drive cable matches the housing better. When the speedo end is seated, the cable just sticks out enough to engage the gear on the tranny.
Chet
