Hissin
Would these be any good as side pipes. I have them from the forward section back. You can see where they unclip...
Just below the Goodyear decal/sticker lower edge. I had them attached with four Kart springs.
You just need to add a front section 90 degree under the front fender/guard. If you have cut the fender you could a run single pipe under instead of the four primary pipes as a cheaper option.
PM me if you want them...
They were operating and are coated in HPC aluminium..
