White wire...tachometer input....!
Frankym...I have an MSD6AL on my Superformance. The white wire from the control unit is your tachometer feed. Connect this wire to your tach to provide input.
So far as your problems are concerned, I've had no problems with mine, so far anyway, in over 2000 miles. Starts readily, effectively limits RPM to the value on the crystal, etc. Mine is mounted on top of the passenger footwell inside the engine bay. The box is isolated with rubber vibration dampers, and heat has not been no problem so far.
I am suspect of the backfire and vibration you talked about with your original dual point set up. Have you remedied those problems yet? Simply replacing your ignition with an MSD unit won't correct those problems (in my opinion), and may be the root cause of your problems with the MSD box.
MSD6AL's are run by the NASCAR teams and believe me, if there was something wrong with them, they'd be out on their ear. Doesn't seem to be the case.
Good luck...but, I'd suspect your problem doesn't originate with MSD. Keep looking and let us know what turns up.
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
