Old 09-24-2007, 04:08 PM
yamazee yamazee is offline
Default Check the Ride Hight of Your BDR
I just got my BDR back from service, had A/C installed, had a top fitted and they found a bad shock on the right front corner of the car.
I noticed that the spacing between the body and the tire was much lower on the left side than the right side. Took the car to my local guy here, first we thought maybe the springs were not on sitting right in the perch, that was not the case. Had to adjust one side a full inch to get the front part of the car sitting right, the back left corner is still sitting much lower than the right rear corner.
I called my dealer, and he said that every car sitting there is somewhat lower on the left than the right? This makes no sense, and I cant imagine it can be normal? Also the problem I see with adjusting one side so much to compensate for the difference is that is going to majorly affect the tension of the springs on that side, I would think that would be a major problem as far as handling. Anyone who can shed some light on this would be tremendously appreciated. Thanks to all who reply.
