Old 08-20-2001, 09:14 PM
Andy Dunn's Avatar
Andy Dunn Andy Dunn is offline
Send a message via ICQ to Andy Dunn
the four popular places for buying stroker's or stroker kits seem to be Coast, PAW, Speedomotive, and Summit. Here is a piece of an old post on this topic (slanted to 427w, but still applies to 393 etc)
Speedomotive
member Fassnake has a 427w and I believe he loves it
http://www.cobraforum.com/cgi-bin/u...ic&f=1&t=015887
a post with some grumbly words
http://www.clubcobra.com/forums/sho...ht=speedomotive
Coast High
I know of at least 5 members with a CHP's 427w
david truelove
xcessive1
Patrick Roth
Scott S
me
http://www.clubcobra.com/forums/sho...=&threadid=7834
http://www.clubcobra.com/forums/sho...5&highlight=PAW
I think everyone is very happy with their engines.
I haven't read much from people using PAW kits but I know two or three members went that route.
If I was going to do it, I would use the shopping list on Summit's website. If you price it out, it costs probably the same as buying the engine completed...see what you think
from the trickflow site
http://www.trickflow.com/articles/st..._st_2_body.htm
Summit Racing Equipment
393 Stroker Parts List
Block:
1979 351W with .030" overbore
Crankshaft:
Summit cast 3.850" stroke (SES-5-53-05-000)
Connecting Rods:
Summit H-beam, 5.955" long (SES-5-48-05-200)
Pistons:
Trick Flow/Arias 10:1 forged (TFS-51404010)
Piston Rings:
Speed-Pro plasma moly (SLP-R9771035)
Main Bearings:
Federal Mogul (FEM-5078M)
Connecting Rod Bearings:
Federal Mogul (FEM-3380CPA)
Camshaft Bearings:
Federal Mogul (FEM-1204M)
Camshaft:
Crane hydraulic roller (CRN-449761)
Roller Cam Retrofit Kit with Lifters:
Crane (CRN-44306-1)
Timing Set:
Cloyes True Roller (CLO-9-3135)
Harmonic Damper:
ATI (ATI-918911)
Oil Pump:
Melling high volume (MEL-M83HV)
Oil Pump Pickup:
Moroso (MOR-24514)
Oil Pump Shaft:
Ford Motorsport (FMS-M6605A341)
Oil Pan:
Moroso 7 quart (MOR-20520)
Cylinder Heads:
Trick Flow Twisted Wedge R-Series (TFS-52400002)
Rocker Arms:
Trick Flow roller, 1.6 ratio (TFS-51400520)
Pushrods:
Trick Flow chromemoly, 8.500" long (TFS-21408500)
Valve Springs:
Crane (CRN-99895-16)
Valve Covers:
Trick Flow cast aluminum (TFS-51411802)
Intake Manifold:
Edelbrock Victor Jr. 351 (EDL-2981)
Carburetor:
Holley 750 cfm double pumper (HLY-0-80528-1)
Distributor:
MSD Billet (MSD-8578)
Spark Plug Wires:
MSD (MSD-31329)
Water Pump:
Meziere electric (MEZ-WP111B)
Water Pump Blockoff Plate:
Meziere (MEZ-WP113B)
Flywheel:
Ram (RAM-1527)
Gasket Set:
Trick Flow (TFS-51400915)
Main Cap Studs:
ARP (ARP-154-5403)
Cylinder Head Studs:
ARP (ARP-154-4003)
Camshaft Bolt:
ARP (ARP-255-1001)
Harmonic Damper Bolt:
ARP (ARP-150-2501)
Rocker Arm Studs:
ARP (ARP-100-7101)
Flywheel Bolts:
ARP (ARP-350-2802)
Engine Accessory Bolt Kit:
ARP (ARP-554-9503)
Expansion Plug Kit:
HPX (HPX-710-585)
Valve Cover Hold-Downs:
Summit T-handle (SUM-G3421)
hope this info is useful
Andy
http://www.cobralads.com
