I had to ask that question too some time back, but if you think about it logically the answer is simple.
You want maximum area to filter through, so putting the
oil to the outside of the filter to then drain back via the narrow internal passage gives the biggest initial surface area on the filter.
Some remotes will have
oil in and out marked too. Don't start to do like I did, in to in and out to out. Detected this before I started the engine in ernest, thank God!
