Old 10-01-2007, 07:34 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Please help!! grinding from toploader
Hello All,
I am experiencing a grinding noise from my tranny when I engage it in gear. Everything was fine before I removed the trans to get to the back of the block to fix my pressure releif valve on my 427 FE.
Here is the problem:
When I start the motor and idle everything is fine. When I press the clutch I hear a grinding noise in netural. As soon as I release the clutch the noise goes away. If I try to turn off the motor and put it in gear then start the motor with the clutch pressed in, the noise is there even louder. I have tried releasing the clutch while making the noise and the car moves without the grinding noise. The noise is intermittent.
Here is my setup:
Centerforce flywheel
Brass pilot bearing
Centerforce clutch
Centerforce pressure Plate
Lakewood Bellhousing
Top Loader Trans
Tilton Hydraulic Release Bearing
I verified through the fork hole in the side of the bell housing that the release bearing moves about 3/4 to 1 in. travel. I have also bled the system several times.
Can someone shed some light before I pull the tranny.
Please help
