Old 10-01-2007, 09:28 AM
patrickt patrickt is offline
Originally Posted by WarrenG
I would also recommend the quick release steering hub. It makes getting in and out of the car so much easier and it gives me a little more secure feeling knowing that the car doesn't have a steering wheel when I can't keep an eye on it.
I always second Warren's recommendation on the hub, but for a different reason (although his reasons are good ones). If you are like me, you just might want to have your steering wheel canted in one direction or the other (as opposed to plum straight) so that you can see your dash gauges better. Having the hub makes adjusting your steering wheel pretty darn easy. Regarding the heater/defroster, I love mine -- even with a big FE under the hood. It will make Fall and early Spring driving much more enjoyable and with a shut off valve on the manifold it adds no additional heat during the warm months.
