Old 10-01-2007, 12:06 PM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Default Tremec TKO 600 vs Tremec 3550...
#770 came with a Tremec 3550, which is a nice transmission, agreed. But, the addition of a Pro 5 shifter made it even nicer, I think. My only complaint was with the 3.73 PosiTrac rear end, at 70 mph, you were doing 3000, or so, rpm. Not dangerous, by any means, but loud. Plus...you basically had no first gear. First gear was from here to there, and there was the other side of the intersection. Clearly, the 3.73 rear end was not an ideal choice for a 2500 lb vehicle.
But, as was the rage a couple of years ago, I upgraded to a TKO 600, with a .82 overdrive. At the same time, I switched to a Torsen 3.27 locker rear-end, from the 3.73 that came installed. Now...I had first gear back...and at 70 mph, I'm turning a little less than 2600 rpm....much more civilized. Plus, the TKO has no need for a Pro 5 shifter. The shift is smooth and positive using the factory installed shifter. I retained my "Jordan shifter"...which is really just the lever and nothing more...but it feels nice - your hand falls right to it - and since it's shorter it has a physically shorter amount of travel.
But...all in all...I think you'll be pleased with the TKO 600, and there's really no need for a Pro 5 shifter. Hope this helps...
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
