Old 10-01-2007, 01:02 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
clois,
I was not asking about removing the tranny because of bleeding purposes. My reason for asking about the removal of only the tranny was because,
I dont have a removalable tunnel in the car and the bellhousing will not make thru the frame rails. So, the first time I removed the tranny I unbolted the bellhousing from the motor. Then unbolted the bell housing from the tranny. I twisted the bellhousing to slip it thru the rails. Finally, lowered the tranny to the floor. This was a pain in the @$$.
Also, I was told to try to bleed the bearing without the pedal stop in place?????
Wouldn't that over stroke the bearing and cause a leak. Can you explain how you bleed your system?
