Old 10-01-2007, 01:15 PM
eschaider's Avatar
If you choose to use the Mark VIII fan and you get the later '98 version it does have a significant appetite for power. The starting amps can exceed 100 and if you run it on high depending on how closely packed the cooling fins are and the restriction the radiator provides you will have a steady state appetite for 38 - 50 amps. Needless to say wiring needs to be up to the job.
Ed
