Coloradocobra,
Thank you for your response. Hmmmmm. Its funny you should mention that. While repairing the pressure relief valve I noticed that my starter did not sit completely to the block. I had to grind alittle bit on the body of the starter to make it sit completely flush to the block. I will definitly pull the starter and check to see if this is the problem. It was not much of a grind but you never know.
Thanks
