Hi Paul
Sideshow gave me the same advice so I found ez2wire. He sells all brands painless, American autowire etc etc. I rang him and ended up getting American Auto wire 15. The whole kit is top quality, the wire, the wire labelling the crimps the instructions etc. As sideshow also says there are still alot of things you will need to sort out namely the way your switches (they do provide some) will interface to the harness. What I have found is the relay/fuse box is very tidy and compact everything in a square hand width and well labelled. I have gone through all the connections and soldered everything. You wll need to buy a few things like the wire to light connectors, wire conduit, master isolator switch, insulation tape.
But man what a feeling when you turn the switch and everything starts buzzing and flashing. No smoke yet (touch wood).
Bruce
