  #49 (permalink)
Old 10-03-2007, 12:24 AM
sideshow sideshow is offline
http://www.ezwiring.com/
are these the wiring looms which have a bad name
ive used a few without any probs
ive got one here ill double check it
but half the time it might be the other end of the wiring where the customer has crimped his own terminals onto it and did a crap job and its come out
i have bought 600 dollars worth of crimpers so i can do basically any terminal of the holden looms from the tiny ecu ones to the bigger ones
anothe rthing i do with these premade loom is use bigger grade alterntor wiring and use good thickness battery cable and cable lugs
i buy around 1000 bucks worth of wirin and terminals every few months
from that site u can buy a 12 fuse or a 20 fuse
when i buy the 20 fuse i modify it so i can use some of the fuses for the engine ecu
so then i do not have to run fuses next to the ecu for the engine
but most people dont know how to
so when people sned me the loom for modifyng i add a small fusebox just for the engine so with 4 or so fuses near the ecu all u really need is like a 12 fuse wiring loom
unless yr goin to run alot fo extras
my website
www.sideshowsperformancewiring.com.au
