these are for l76 only
u supply main engine loom and i add my bits to get everything on engne to work with minimal work for customer is 700
if u have no engine loom what so ever then i can supply l76 engnine loom and then add my bits to make it complete loom as above for 1200
Accel pedal is 100
Front o2 sensors 180 each
Rear o2 sensors 115
Air flow meter 310
Knock sensors 70 bucks each
Engine ecu is 820
just keep in mind to get the missing bit of the l76 ecu harness u need to buy the front body harness and im not sure if this does the pdeal aswell sells for over 800
my loom is 700 comes pre wired with new micro relays fuses wiring to fans pump gauges air flow meter and air temp sensor plug which are part of body harness and comes with 2.1 m cable and plug for throttle pedal
afew cobras ive done have 2.1 m from ecu to pedal so ive been using that measurement but can adjust easily by request
if i get your looms then u should get it back within 2 to 3 weeks
thanks
jim
