Hello Bob,
The closer 2121 gets… the more questions I have.
Could you provide insight to the following for the drop dash option with standard gauges?
- I’d like to swap out the mechanical
oil pressure,
oil temp and water temp gauges for some with electric senders. Are they available & can the wiring harness accommodate this change?
- Is it possible to replace the Ammeter with a Voltmeter? Again, can the wiring harness accommodate?
As always, thanks for all your help!
289FIA
