Thread: Changing oil
  #34 (permalink)
Old 10-03-2007, 10:18 PM
CSX 4027's Avatar
CSX 4027 CSX 4027 is offline
Cobra Make, Engine: Sold 3047 & 3002 in 2012
Default Oil
I know changing often sounds like a good idea as in your example below but there's a catch.
If you are using modern oil with high detergent, you are not giving the oil a chance to do it's job. Too often is not good. Those oils work best when gone at least 3000 miles.
If you are using a non street legal low or no detergent oil like Valvoline VV851 20w/50, you will be better off. It has less than half the detergent of modern oil and need to be changed every 500 miles or 3 months.
There have been any articles quoted on CC about oils but little about the change intervals.
Originally Posted by SantaFe66
I bought a suction device from Griot's garage (http://www.griotsgarage.com/catalog....2050&SKU=10186) and suck the oil out of the dipstick tube. No lift needed. I have an 8 qt., front sump pan and get almost all of the oil out. I also just jack the left front to get at the filter and drop it into a cutoff milk jug.
I'm not sure it's all that important to get every drop of oil out if you change it often enough.
I change mine every 60 days no matter how many miles I put on during the spring and summer months. Cheap insurance. I also use premium, high quality filters, not those Fram cheapies.
By the way, there is a suction device that you manually pump the suction with a handle like a bicycle pump. It's cheaper than the one at Griot's and made by the same company (Mity Vac). They also make a very cool vacuum brake bleeder that works great.
Just my .02.
Paul
Steve Sunshine
www.competitionlife.com
"Hurry Up And Live"
