Old 10-04-2007, 05:26 AM
strictlypersonl strictlypersonl is offline
Originally Posted by 289FIA
- I’d like to swap out the mechanical oil pressure, oil temp and water temp gauges for some with electric senders. Are they available & can the wiring harness accommodate this change?
- Is it possible to replace the Ammeter with a Voltmeter? Again, can the wiring harness accommodate?
289FIA
I can add 3 wires that pass through the firewall but they're not in the standard harness. No big deal if I can associate a harness directly with your kit.
Are these (SW-82218 set) Stewart Warner gages OK? The clock will have to be a different style.
If you want something different, we'll have to talk...
