Old 10-05-2007, 08:41 AM
1966plus's Avatar
1966plus 1966plus is offline
Default My FE has arrived :)
I know it's GT40 bound but my FE had been delivered from Huddart Engines in the UK
Slightly over the spec I originally went for, but no complaints from this end
560bhp at 6000RPM, 580ft/lb at 4000 RPM
Engine Front
Engine Rear
Engine Left side
Engine Right side
The replacement "Baldy" rocker covers
1973 block.
Eagle crank and rods.
Custom forged pistons @ 10.5 compression.
Steel damper.
Internal balance.
Edelbrock alloy heads with Victor manifold and 750cfm Holley double pumper carburettor.
MSD distributor and control box with 6000rpm rev limiter.
Edelbrock alloy water pump.
Comp Cams mechanical cam and roller rockers.
Complete AVIAID dry sump kit with 3” oil pan, 4 stage pump with Gilmer drive.
Craig
www.miragemk2.com
