Old 10-05-2007, 08:43 AM
C0V3R C0V3R is offline
Default tremec tko600 or driveline problems
I have a bit of a nasty clunk in the drive train that appears when I let off the throttle quickly or apply it after coasting. It seems like its related to loading or unloading the drive train.
I have:
- New TKO 600
- New drive shaft + uni joints
- Replaced the whole diff chunk after thinking that might be the issue and to get better gear ratios (still makes noise, but it could be similarly worn to the old one)
I just ran it up on jack stands and its making clanging rattling noises intermittently (but frequently) and when you blip the throttle you get a little more.
Ok heres a video of the lovely gearbox noises, mostly just idling in second with a few blips of the throttle. The noises are clearly emanating from the gearbox.
http://www.youtube.com/watch?v=pdHgAWKK3ns
Havent found anything much useful about this sort of problem yet.
Any idea on whats causing it and/or how to fix it?
