Originally Posted by tchrome
Hey Guys, I Have A Top Loader 4 Speed. How Can I Tell What Year It Is ? Also Can You Tell Me The Best Place To Get The Parts I Need To Overhaul It?
there should be a metal tag on the front passenger side of tranny with a code HEH or RUG, and then look on the web site below to decode.
www.4speedtoploaders.com
I Recently Put New Brake And Clutch Master Cylinders In My Naf Cobra. Since , I Am Having A Gear Grinding Problem. I Have Blead The System A Couple Of Times And It Looks Like The Slave Cylinder Is Engaging The Clutch All The Way, But Unless I Double Clutch, After Starting The Car, I Grind Going Into Reverse And It Is A Problem Down Shifting Most Times If I Don't Double Clutch It. I'm Thinking The Syncro's Are Bad And Maybe It's Time For A Rebuild. Any Suggestions?
Your synchro's may be bad, but there are no synchro's for reverse, so my guess is that your clutch is not completely disengaging, needing to double clutch to prevent gear grinding. Your system may not be completely bled. You need to get a clear tube on your slave cylinder bleed valve , and pump your clutch, bleeding it more until there are no air bubbles. If you still need to double clutch, then check for throw out bearing preload adjustment, such that there is alittle play before engaging the pressure plate. If that doesn't solve your problem, then check the distance the slave cylinder moves with the pedal pressed to see if you are getting reasonable movement.
good luck.
