Old 10-08-2007, 11:21 AM
Jimi G's Avatar
Jimi G Jimi G is offline
I would recommend the TKO600 it will take all the power you can throw at it and it will bolt right up in place of your T10. It will come with a 26 spline input so you would possibly have to change your clutch disk to a 26 spline disk. The only other difference you will run into is that they are an internal linkage transmission unlike your T10 which is an external linkage transmission. Basically your shifter is offset 2" towards the drivers side and the TKO will come up in the center. There are off set shift tops or you can just open up the hole in your tunnel a little bit. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
