Old 10-08-2007, 02:38 PM
PARKERPOWER's Avatar
PARKERPOWER PARKERPOWER is offline
Cobra Make, Engine: HM1035 with 521ci, 612fwhp
Send a message via AIM to PARKERPOWER
I have a hurricane and I put a 460 in it. It will fit without too much trouble, but it sits so far down in the frame that you don't have a lot of ground clearance. I also used the victor junior intake and it is so tall that the standard scoop will not fit, I had to go with an after market about 3.5 to 4 inches tall. You will also have to go with a hydraulic throw out bearing because the fork will hit the frame and if you cut it off to clear you loose all your leverage for a slave cylinder to work. I also stroked and bored the engine to a 521 and put the super cobra jets heads on it and this thing has so much power and torque it will spin the tires in third gear from a dead stop. if I had it to do over again I don't think I would go the 460 route mainly because of the ground clearance problem more than anything else.
Richard
