Wanted to share some more info on this subject....
We loved the drivers side spacers so much we ordered some for the passenger side. Here is what we found..Driver's side has a threaded bolt on the bottom. You screw the top of the spacer into the seat bolt, and the bottom bolt goes through the floor pan and the washer/nut attaches underneath.
Now what they don't tell you when ordered is the passenger side spacer is too large...it tilts the seat back so much that you would have to drill new seat mounting holes in the floor pan so the seat back isn't stopped by the rear firewall. What we did was cut the passenger side seat spacers in half..they give enough tilt to make them more comfortable but not enough to where you cant use the original mounting holes. You don't have this problem on the driver side as you can use the slider to move the seat forward enough to counteract this. Of course if someone was 6' 6", it might be more comfortable to drill the new holes all around.
