  #36 (permalink)
Old 10-11-2007, 05:23 AM
SSSammy's Avatar
SSSammy SSSammy is offline
Did the manifold air bleed as Bob said, and I'm not blowing coolant anymore, so maybe that's checked off .. Yes on the big fan, and it is blowing correctly. Chuck, thanks for the timing suggestions, will try to put those in today.
I'm thinking these symptoms could be caused by a defective t-stat. Only coolant passing may be via the drilled hole and the heater bypass hose. Will probably pull that thing off today or tomorrow and test it.
Sam
