Thread: Engine Wiring
Old 08-23-2001, 06:36 AM
dakota dakota is offline
Thanks Jack,
Like you said, I need 12V running straight to the DUI, no ballast resistor. I do have an electric choke and have 128 hooked up to it. There are two wires labeled 128 and 128A running into a single terminal which is plugs into the electric choke. I am assuming I am going to have to run a splice from there up to the DUI. Where should I splice the new wire into?? Right off of the existing terminal with both wires or one or the other of the two wires (128 or 128A).
Thanks,
Wade
