Old 10-11-2007, 05:15 PM
boxhead's Avatar
boxhead boxhead is offline
If your using the factory pump then you will see there are 3 outlets on it.
The 2 outer ones are marked F & R.
The F is the feed line, the fuel is pumped out of this pipe and to the filter, the filter has a "T" piece hose conection, fuel is fed into one terminal on the T piece and flows out the other 2.
The T piece is connected to the fuel filter and the 3rd terminal goes back and connects to the "R" terminal on the pump, this is Return.
The regulator is built inside the pump assy in the "R" pipe end.
The centre pipe is for the vapour canister line.
Cruising in 5th
