The L32 supercharged 3800 GM engine used in 2004+ models is a dead head. The ecm adjusts the fuel pump power to adjust pressure and flow. System works fine in our (non cobra) kit cars when the factory fuel pump is used. And the matched injectors are used. I would not be afraid of the system, but would want to use the same fuel pump they built the system around. Assuming it works like the GM system does.
RP
