Ron,
The grease is on the drive shaft for initial start up--before the tranny fluid can get back there to lube the seal. After you drive for a bit, the tranny fluid will do all the lubrication the seal needs.
(I assume you are referring to the output seal when you say "rubber bushing.")
David
