Old 10-13-2007, 12:06 AM
Jamo's Avatar
Jamo Jamo is offline
Super Moderator
Originally Posted by Sal Gerace
Is a shoulder belt required and or reccomended for an event like this? Also what tire pressures are run on the track with Goodyear Billboards.
Yes...use the shoulder belts and consider an anti-sub (ie., 5 point).
Use the Billboards, but certainly not with as much pressure as Bill's suggesting. I run about 23 up front and 20 out back. You could start off with 24 all the way around and see if you like it...it'll probably be just fine for the first time. Forget phuking with tire temps and playing with the pressures too much. Just go out and drive well within your comfort level and enjoy it.
Brake straight!
Sal...you'll be fine.
Jamo
