Old 10-13-2007, 07:18 AM
Rebel1 Rebel1 is offline
That looks like way too many shims. Total of three is normal.
Series 1 upper arms are handed.
Series 11 upper arms are identical front and back.
Standard Jaguar castor is 2.25 degrees +/- 1/4 degree but that is for a much heavier car. 4 degrees is good starting point for a much lighter cobra.
Each standard shim (1.6mm) will alter castor by 1/4 degree.
Are you sure you have series 11 lower arms. Using series 1 lower arms will reduce castor by 2 degrees.
