Originally Posted by vector1
will a reverse mount starter fit or does it have to be in stock location?
Actually I do not know the answer. It would be my assumption that the tunnel is too tight for the starter to fit. Also the rear mount units are on the top of the bell housing if I recall. I cannot see any reason to mount something that heavy any higher than need be. (CG you know.)
John Marsey has the small bell housing with the starter going forward. That bell housing is above the bottom of the chassis.
You might wish to ask John about his setup. He has some really good experience with clutches etc.
John's bell housing
