Old 10-14-2007, 06:59 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by kris-kincaid
. The standard Shelby fuel system works fine, and you shouldn't need all sorts of large fittings and complicated fuel lines. There are a lot of 500hp and 600hp Shelby cars running around with the standard setup.
Kris, my car runs fine on the street, even OK runs on the chassis dyno. But, I can tell you with drag racing, the car starts to sputter and miss 1/2 way down the track, and on a speed way, on a back stretch, it seems to lose power, "hit a brick wall". Well, if I get this straightened out, I'll let you know, but I think there is a fuel supply issue with my car, as set-up, with the Carter super street mech pump and the stock electric pumps. What I need to do is to take it to the strip again. Not enough time this year.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
