  #48 (permalink)
Old 10-15-2007, 03:04 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
For a quick check on the cam timing---both lifters should be aprox the same ht out of the lifter bore when the cylinder is at tdc on the overlap stroke--in the old days this was where we started on setting the cam timing---
IF the lifters are not aprox equal , your cam timing is way off
You said that he had a .215? number on the indicator---if that was on the intake valve( and 000 on the exhaust) you can see that by splitting the number you would have .100 on each valve, which would be more than enough.
Jerry
