Kramer, yes I did. They were very helpful. Then I contacted a Cobra shop and they machined the base plate to fit over the stacks. They fit just fine and do not contact the hood. Good luck to you! You must run filters with the TWM's. Even if you simply run the car on a road course, used tire rubber WILL get kicked up and in to your engine compartment. I have found more than one chunk of rubber lying on my intake manifold between the stacks. Don't take the chance and run the car without filters!
Don't underestimate the predictability of stupid!
