Thread: Leaks all over
Old 10-20-2007, 11:26 AM
mrp_e mrp_e is offline
Cobra Make, Engine: Superformance + Ford 460 (550hp)
Originally Posted by TRIG
you can bleed the clutch at the slave where it's connected to the clutch fork. Very simple, just have someone sit in the car and push the clutch to the floor the turn the bleed screw to let the air and fluid out, tighten the screw, release the clutch pedal, push it back in, turn the bleed screw, tighten it and so forth. You get the picture. Once you get all the air out top off the clutch resivoir.
trig2275
thanks very much trig. is the bleed screw the silver one here in the pic?
http://www.clubcobra.com/photopost/s...size=big&cat=9
or, is it the dime-sized black plastic circle below it (not sure that even turns)?
