Can't thank you all enough. I jacked the car up, found the bleed screw and had my wife do the broom stick trick with the clutch. it took 5 or 6 rounds before the pressure in the pedal returned. took it for a spin and over the course of a few miles the pedal pressure got right back to normal.
Now I gotta find that leak....
PS - i noticed while under the car that there's no nut at the end of the bolt sticking out toward the back of the car from the clutch master cyliinder. should there be one? in roger's photo, it's the bolt sticking out right side of the black rubber flexi thing.
again, thanks to trig, roger, flip and patrick
