Thread: Tonneau Cover
Old 08-24-2001, 03:58 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Default Not a problem
Jack,
Any auto upholstery shop can make you a tonneau cover for the car. The big thing is, do you have a soft top, or plan on adding a soft top?
The reason I ask is the soft top will come with the " clips-buttons" in place. If you already have the soft top and the studs mounted then matching the tonneau will not be a problem. If you do not have the soft top and decide to order one at a later time, make sure that they do NOT intall the clips, but just supply them with the top.
Does this make sense?
DV
