Old 10-21-2007, 06:54 PM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Originally Posted by Rick Parker
If the break in the line inside the tank was above the fuel level it wouldn't bubble when he blew into the line from the carbs, right. Suggest looking at the pump, they are notorious for short service life and much has been discussed by others previously, regarding that very subject.
Not necessarily. Blowing you are pushing down on the fuel with help from atmospheric pressure, when sucking the atmospheric pressure is working against.
The pump could be bad but I would check the line first.
