Old 10-22-2007, 08:20 AM
undy's Avatar
undy undy is offline
Question Intake manifold gasket glue??
I've got my new Keith Craft stage II heads ready to go on my Pond 482. The Nitro Seal gaskets that I bought just won't work. The gasket ports are way too small for Keiths larger CNC'd ports. I will be utilizing a set a gaskets Keith gets custom made for his CNC'd heads. The problem with these gaskets is that they're 100% composition, no metal sandwich. I'm leary of them as they're similar to Fail-Pro's Print-O-Leak. Keith says he glues them tight to the head (entire contact area) and he doesn't have any gasket migration/leak problems. This is all assuming the right angles (head to intake) and clearances. My question is, "What's the best adhesive to use for this duty??". I'll be using "The Right Stuff" for the gasket to intake surfaces, along with the end gaps too.
Too many toys?? never!
