the backfire through the carbs can be an air leak through the intake gaskets, dirts in some of the jets in the carb or a dirty valve seat(check the compression on #4). Also check the accel pump squirter. It has a small ballvalve inside. If it sticks it will be pulling gasoline out of it all the time.
Nothing sounds better than a Cobra in a Tunnel !
