Old 10-22-2007, 02:17 PM
undy's Avatar
undy undy is offline
Originally Posted by wrench87
another helpfull idea is to cut the head off 4 bolts and put a slot in each at one end and screw them into the heads so when you put the intake on it will act as a guide and you wont be moving the intake around wich might move the gasket. i do this on the small block i dont know if it works on a fe
..won't work on the FE due to all the intake bolts being an splayed. It would make it easier though.
