Old 10-22-2007, 03:11 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
I will definitly let you guys know how it works. I have been battling a bleeding issue with my brake and hoping this will help out with the problem.
FYI,
I had the brake M/C chromed. I think the process change the characteristics of the M/C which is causing it to leak from the piston inside the footbox.
This company that I am purchasing the Phonenix pump also has a hone tool for 3/4 bore and 7/8 bore for the M/C. I am hoping that this will solve my leaking problem along with the seal rebuild kit.
