10-22-2007, 09:28 PM
NJ
Cobra Make, Engine: ERA 389 427s/o
Originally Posted by Chaplin
Dean, Jim or Loadco-
I have the same canton oil t-stat sitting on my shelf in the garage which I have not installed yet, but am going to in the next few weeks. However, I have a question for you.
Did you have to cut down the threads on the fitting that screws into the "out to oil cooler" hole? On my t-stat, it does not look like you can screw in a std fitting without the threads hittig the plunger that is inside the t-stat.
Also, Loadco, were you able to make the set up work using the existing oil lines on your ERA? If not, how much new oil line did you need and how many fittings- trying to figure out what I need to order.
Thanks
At least you hope to be doing that!
