Originally Posted by convincor
Disconnect the linkage at the carb and see which has resistance. Linkage or carb. Take a look at the throttle plates for interference with the intake or gasket. Got a good return spring on it??
I do have a return spring on the throttle linkage. No hose clearance issues. The throttle linkage itself is moving fine and so is the cable. What else could be sticking?
