Old 10-23-2007, 10:45 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Not enough castor there Bobby. Put 4 degrees in and it should be a lot more stable. The toe out won't help either, you should probably have a little toe in on the front.
A bit of toe in on the rear is good as it'll try to toe out under brakes when you want the car to be stable and run straight.
Mike Murphy
Melbourne Australia
