Old 10-23-2007, 11:24 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Bad handeling is usually caused by improper alignment.
Mine seems to be just rock solid at highway speeds (80mph). On the track I'm very comfortable with 140mph down the front stretch.
Caster 4*
Camber 0.25-0.5* (for the track I increase this to 1.5*-2.0*)
Toe in 1/16" total
Have you checked your bump steer? If it's a random tug to one side or the other, is it associated with irregularities in the road surface?
Before aligning the car, make sure you have the ride height set exactly where you want it. If you're going to adjust corner weights, do that first.
