  #32 (permalink)
Old 10-24-2007, 02:16 AM
Keithc8 Keithc8 is offline
Default FE Builders
There are several builders to choose from and I am sure that a lot of them can do you a gret job. I do know that we are the only ones that have several customers that hold NHRA stock and super Stock records with an FE engine. We were the first to put a 428CJ Super Stock engine with factory compression, heads and carburetor into the 8's making over 740HP.
We also have original used side oiler blocks, new side oier blocks, new Shelby blocks, new Pond blocks, new Genesis blocks all in stock. New cast steel crankshafts, new steel 4340 crankshafts, new 4340 billet crankshafts, original rods, billet rods, original heads, Edelebrock heads and about anhy other FE part in stock. We are one of the few engines shops in the country that has their own CNC block, head and valve job machines to perform the work on the engines. We can supply most any combination in as little as two weeks when required. Plus we build about 80 FE engines a year that go allm over the country.
When it comes to delivery time, quality, horse power, durabilty and drive ability at a great price we are pretty hard to beat. We have a special right now on a Pond aluminum block 482C.I. FE with our Stage 2 CNC heads, hydraulic roller complete of the dyno for 16,500.00. This engines makes a conservative 575HP with small camshaft and 9.5 to 1 compression and about 600HP with 10 to 1 compression and one size larger camshaft. Our equipement, buying power and location helps us keep our over head down so that we can offer an aluminum FE engine for not much more than an aluminum small block engine. Give us a call and maybe we can help. Keith
Keith C
