Thread: tire pressures
Old 10-24-2007, 04:37 AM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Skip,
I run 24psi rear and 26psi front in 295/50 15 and 235/60 15
I copied this from a thread on the Backdraft site.
While checking out BDR473 upon arrival, the air pressure in the 17" Goodyear F1 tires varied from 23-28 psi for the four tires. The manual for 473 indicates 28 psi front and 29 psi rear. As phone calls are cheap on cell phones these days, I called Backdraft in Boynton Beach and they recommended what the manual indicated - 28 psi front and 29 psi rear. I filled the tires to these tire pressures and the ride appears OK. I have had a minor tire scuff on the bottom inside of the left rear fender well; this happens if I go over a short dip in the road and the car goes up and down fast. Leaves a minor scuff on the edge of the F1. Nothing on the right side.
See if this link will take you to there site.I am surprised Jay or Reg haven't responded to this thread. They are usually good about that.
http://www.backdraftboys.com/forum/t...sp?TOPIC_ID=20
